2005 Ford F250 General information
2005 FORD F-250
62,100 MILES • V8 • 2WD • AUTOMATIC
HYWAY_HOBO
in the ford f 250 are the power steering pump and power brake booster connected, ?. If so do they both need to be replaced if one or the other become defective
Jun 29, 2009 at 5:50 AM
BUDDYCRAIGG
  • 2,262 POSTS
on some vehicles, they are. mostly diesel engines.
the brake power booster is driven by the power steering pump. normally called Hydroboost.
you would be able to see lines from the pump or steering gear box going to the booster.
and no, normally you would not need to replace both.
Jun 29, 2009 at 7:38 AM
