2005 Ford F-250 trying to find the cause
160,000 MILES • V8 • 4WD • AUTOMATIC
RODTHEDRILLER
When driving at higher speeds 60 plus and hit bumpy spot in road the front tire start shacking severly wont stop till slow down alot. It dosnt happen very often or at slow speeds . The steering is tight drives well . I recently took to shop to get repaired they replaced ball joints brake rotors and steering stableizer. I had a friend with a F-350 with the same problem is this a common ford problem. What should I try next to stop it ?
Oct 1, 2010 at 5:56 AM
BLACKOP555
  • 10,386 POSTS
not a common problem at all. and highly unsafe.
go under vehicle and have someone wiggle steering wheel fast with front end off the ground and feel for play in the tie rods. ball joints, stabilizer bar mounts. and suspension components.
Oct 2, 2010 at 6:41 AM
TECH1FORD
  • 102 POSTS
It is a reconized problem by ford there is a service bullitin on the problem ford repair is to replace the steering wheel it only happened in 2005 trucks take to the dealer they will give you all the info.
Oct 9, 2010 at 5:28 PM
