2005 Ford F-250 Two Wheel Drive Automatic 135668 miles
On startup dash show TBC Fault. When mileage reset is depressed fault clears and mileage shows. In the past on rough roads the dispplay has gone blank When brake contol adjust iswitch s depressed either the mileage displays or fault again will again show on dash. Having a trailer conneted has no effect on the display. Will replacing the module correct the problem or could there be another issue?
SPONSORED LINKS
Thursday, September 23rd, 2010 AT 8:11 PM
