2004 Ford F250 SPEEDOMETER GOING WACKY
13,700 MILES • V8 • 2WD • AUTOMATIC
REBORN
My speedometer will go wacky at various times. When sitting at a red light the speedometer will bounce from 0-40, 0-50 but if it bounces to 90 or more it will stall the truck. The engine will restart with no problem. Is this all cause by the speedometer sensor.
Oct 8, 2009 at 1:55 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Maybe fault in speed sensor assembly see diagram.
Does trans shift O.K.? Need scanner to checkout sensor Ford provides no tests other than scanner.
Hope this helps
Thanks for donate
Oct 8, 2009 at 2:13 AM
REBORN
[quote:395a667492="Docfixit"]Hi
Hope this helps
Thanks for donate[/quote:395a667492]
Truck shifts fine and runs fine while moving above idle speed. I have no check engine lights that have come on. I plugged a meter into the socket under the dash and no codes where given.
Oct 8, 2009 at 2:37 AM
DOCFIXIT
  • 18,828 POSTS
https://images.2carpros.com/forum/automotive_pictures/198357_Grafic_3_53.jpg
Code reader will not do the job. Need a diagnostic scan tool. Like Snap-On, OTC, Pro-Link iQ. these will be able to read VSS input and speedo function.
Oct 8, 2009 at 2:48 AM
