2004 Ford F250 power door locks
13,000 MILES • V8 • 4WD • AUTOMATIC
HANUMBER4
the power door locks lock automaticly when the vehicle starts to move. is there a way to disabble this feature without disableling the power door lock?
Dec 5, 2008 at 7:02 AM
DAVE H
  • 13,383 POSTS
Autolock Enable/Disable - Using the Ignition Switch
Another way to turn the autolock feature off/on is by following this series of steps:
Close all doors.
Confirm that the key is in the OFF position.
NOTE:Steps 3 through eight must be carried out within 30 seconds.
Turn the key from OFF to RUN.
Press UNLOCK 3 times.
Turn the key from RUN to OFF.
Turn the key from OFF to RUN. The enable/disable mode is now ready to accept program changes.
Press UNLOCK once to command the vehicle security module to toggle the autolock/relock feature OFF.
Press LOCK once to enter the command.
Verify that the horn chirps one time. There should only be one chirp indicating that the autolock/relock feature has been disabled. If one chirp is heard followed by a longer sound of the horn, the autolock/relock feature has just been enabled. Return to Step 10.
Turn the key to the OFF position to exit the enable/disable mode.
Dec 5, 2008 at 7:18 AM
