2004 Ford F250 Fuel Level Sensor A
87,000 MILES • V8 • 2WD • AUTOMATIC
HAWTHORNE
Hi the fuel gauge reads empty with full tank, check engine light is on, and the code is PO460.
Can you tell me how to trouble shoot this.
Thank You Kevin
Jun 27, 2010 at 2:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
P0460 Fuel Level Sensor Circuit
The most likely culprit for this trouble code would be a faulty fuel level unit, located in the fuel tank. Rarely is it the wiring, but it's always best to check out the wiring at the back of cluster as well as near the fuel tank to ensure it is not damaged/short circuited.
Jun 27, 2010 at 5:25 PM
