Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Body
Door
Chime
2004 Ford F250 door controls
2004 FORD F-250
80,000 MILES • V8 • 4WD • AUTOMATIC
JOHNKC
MEMBER
on my 2004 f250 the door chime headlight chime radio shutoff are all not working any suggestions ?
Jul 12, 2010 at 4:08 AM
BLUELIGHTNIN6
Experienced Mechanic
Hello and thanks for donating Check fuse # 41 (10 amp) in the central junction box. The CJB is located under the driver's side of instrument panel.
Jul 13, 2010 at 10:27 AM
JOHNKC
MEMBER
Jul 14, 2010 at 12:05 AM
JOHNKC
MEMBER
If it is not the fuse what else can i try?
Jul 14, 2010 at 12:06 AM
BLUELIGHTNIN6
If it isn't the fuse then there is most likely some wiring that is damaged or loose behind the door panel .
Jul 14, 2010 at 3:45 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
