2004 Ford F250 DOME LIGHT STAYS ON
2004 FORD F-250
50,000 MILES • V8 • 4WD • AUTOMATIC
TODDWOLF
MY DASH SHOWS A DOOR AJAR WARNING LIGHT, ALL DOORS ARE SHUT TIGHT & THE DOME LIGHT AND THE TRUCK BED LIGHT STAY ON FOR A VERY LONG TIME AFTER SHUTTING THE TRUCK OFF?????
Jan 2, 2009 at 12:31 PM
BUDDYCRAIGG
  • 2,262 POSTS
one of the door switches probably need to be adjusted or replaced.
Jan 2, 2009 at 12:37 PM
HARLEYGUY64
according to ford, there is no pressure switch in the door jam like on other cars, it is in the door handle that tells when the door is open or closed.
I ended up just pulling the fuse so i have no dome light which sucks at times, but the map lights still work so use those.
Mar 8, 2009 at 10:16 AM
BUDDYCRAIGG
  • 2,262 POSTS
it would be time consuming, but if you want to fix it, unplug both switches and see which one makes the light go out.
you'll probably have to take the door panels off to get to it.
Mar 12, 2009 at 9:23 AM
