2004 Ford F250 Dash gauges or Instrument Cluster
2004 FORD F-250
50,000 MILES • V8 • 4WD • AUTOMATIC
PAMNDONSTEIB
All of my dash gauges went out at time; engine oil pressure,Transmission temp, Eng temp, Engine RPM and speed odometer. I checked all the fuese under the steering column and all appear to be OK.
What could make all the dash gauges go out at the same time?
Sep 18, 2008 at 7:16 AM
2CARPRO JACK
  • 11,533 POSTS
Need to use a test light and be sure that fuses 30,41,45, 35 all have power in and out with key on. 30, 45 are power with key on, others are always hot.
Sep 18, 2008 at 12:33 PM
PAMNDONSTEIB
[quote:92c9caa6e8="2CarPro Jack"]Need to use a test light and be sure that fuses 30,41,45, 35 all have power in and out with key on. 30, 45 are power with key on, others are always hot.[/quote:92c9caa6e8]
I called the dealership after I checked the fuses and they indicated that there is a printed circuit card that drives these gauges and that could had gone bad. Where is this printed circuit card located? Can it be tested to verify if it is good?
Sep 19, 2008 at 6:33 AM
2CARPRO JACK
  • 11,533 POSTS
It is on the back of the dash/instrument cluster.You need to remove the gauge cluster and turn it over to see it
Sep 19, 2008 at 6:59 AM
