2004 Ford F250 Change of door mirrors
2004 FORD F-250
35,000 MILES • V8 • 4WD • AUTOMATIC
MACK FORD A1
Can I change my paddle style door mirrors that are power and are not heated. To teleascopic power and heated mirrors with the stock wire harness in my door panel. So far the Ford parts dealer can not find the right mirror and they are not sure of the fit. Would you also have a part number if there is one.
Thank You
Feb 19, 2010 at 1:12 AM
DR LOOT
  • 2,311 POSTS
The only way you can replace your mirrors to telescopic is if you're truck came with those mirrors from the factory, you will have to disassemble the door to see if it was prewired from the factory for the heated mirrors.
Feb 19, 2010 at 3:28 AM
GINO.BURNS
I'm kinda stumped on the reply you recv'd " The only way you can replace your mirrors to telescopic is if you're truck came with those mirrors from the factory..." as I replaced my paddle mirrors with the telescoping ones. I ordered them off e-bay (Super cheap compared to dealer price) then cut the pig tail off the new ones and replaced them with the original ones from the paddle mirrors in order to directly hook them back up. Granted this may not solve adding heated mirrors or ones with turn signals but if you really just want the telescoping ones then this may work for you.
Mar 30, 2010 at 6:20 AM
