2004 Ford F-250 brake lights and turn signal
2004 FORD F-250
80,000 MILES • V8 • 4WD • AUTOMATIC
BSCHLECHTINGER
about 1 month ago my right turn signals stopped working. I checked the fuses all good, same with bulbs and relays, Iguess its the turn signal itself? now today Ifound out my brake lights arent working. I replaced the burnt fuse and looked in the switch it looked worn and like it had been arching, so I replaced it, still no brake lights? why? Im pretty sure the switch is in the exact same way the other was. please help Im asking for a ticket, or wreck driving around with no turn signal and no brake lights
Oct 18, 2010 at 1:54 PM
TECH1FORD
  • 102 POSTS
there are 2 fuses that control the brake lights 2.34 and 2.18 they run to the brake pedal posistion switch check all the fuses did you get the turn signals to work properly now.2.34 is the first fuse on the bottom of the panel and 2.18 2 up from it. hope that makes sense.
Oct 25, 2010 at 11:59 AM
