2003 Ford F250 violent oscillation
67,000 MILES • V8 • 2WD • AUTOMATIC
PCRS1644
I have spoken with several F250 owners around my year model and they all say that they have had problems with a violent shaking and oscillation of the front wheels and steering wheel. My truck has this problem between 30 and 50 mph and usually happens after hitting a bump or a rough spot in the pavement. Sometimes I can turn the wheel back and forth and which will cease the problem, or I may have to speed up or slow down outside the listed speeds. All of which are dangerous depending on the condition. I have looked at the bolt connecting the pitman arm to the column and that is tight.
Jun 1, 2010 at 11:09 AM
  • 31,937 POSTS
Hi there,
I can only suggest that the entire front suspension and all steering is closely inspected for any faults, i have heard that ford have not had much success in tracking this down, this is a problem that one would really need to be hands on to start any detailed diagnosis.
Mark (mhpautos)
Jun 1, 2010 at 9:11 PM
