2003 Ford F250 PASSENGER DOOR POWER LOCK NOT WORKING
2003 FORD F-250
DSB
Electrical problem
2003 Ford F250 V8 Wheel Drive Type unknown Automatic 90,000 miles
How do you remove the door panel It does not appear to have any screws.
Thank you
Mar 15, 2008 at 4:21 AM
MERLIN2021
  • 17,250 POSTS
There are usually one or two philips in the hand pull area, and a bolt to hold the door handle on, then get the trim panel tool, it's thin with a claw type end, feel around for the plastic clips and pop them out with the tool...the panel clip holding ares will break easily, so be gentle...
Mar 15, 2008 at 4:31 AM
