2003 Ford F250 overdrive not working
JAIMEASG
Transmission problem
2003 Ford F250 V8 Four Wheel Drive Automatic
my overdrive gear is not working neither the light on overdrive switch is not coming on.
Oct 2, 2008 at 10:48 AM
KHLOW2008
  • 41,812 POSTS
Hi jaimeasg,
Thank you for the donation.
Check the Central junction box (Lower left side of dash) for fuse # 45 (10 A).
If fuse is ok, you need to test the OD switch.
Oct 3, 2008 at 6:30 AM
