2003 Ford F250 oil in radiator
2003 FORD F-250
200,000 MILES • V8 • 4WD • AUTOMATIC
AQUATROL
ford powerstroke 7.3 v8 starts and runs has oil pressure but the radiator is full of oil what would cause this has anyone heard of this problem before?
Aug 18, 2008 at 9:24 PM
  • 31,937 POSTS
Hi there,
First check if you have an integrated oil cooler in the radiator and that it has not failed and is leaking into the cooling system, if that is ok, then the problem will be an engine related problem, possibly a crack head at a oil pressure gallery.
Mark (mhpautos)
Aug 18, 2008 at 9:53 PM
APEARSON7
[quote:8e93d49199="aquatrol"]Engine Mechanical problem
2003 Ford F250 V8 Four Wheel Drive Automatic 200000 miles
ford powerstroke 7.3 v8 starts and runs has oil pressure but the radiator is full of oil what would cause this has anyone heard of this problem before?[/quote:8e93d49199] Did you find out what the problem was? I have a 2003 F-250 6.0 with the same problem. If you have an A/T then the only thing we have in common that could be the problem is the radiator is bad???
Sep 2, 2008 at 12:35 AM
