2003 Ford F250 Dipstick read
2003 FORD F-250
72,000 MILES • V12 • 4WD • AUTOMATIC
RKSM
I have a 6.8 v10 4x4 and I recently changed fluid in the engine and transmission. My capacities are 6.0 quarts and 17.7 quarts respectively. I added 6.0 quarts oil and 12 quarts atf and both of my dipsticks are reading as if they are overfilled. I have never had this problem with a vehicle before I am not sure what I should do or what I am doing wrong.
Thank you,
Jan 24, 2009 at 1:06 AM
MERLIN2021
  • 17,250 POSTS
https://images.2carpros.com/forum/automotive_pictures/62217_Forda_1.jpg
These are for dry filling...the torque converter usually hold about half the total capacity! As for the oil, you did change the filter too? if not there's another quart or so in it.
Jan 24, 2009 at 1:20 AM
RKSM
Yes I replaced the old filter. Thank you, I will remove some atf.
Jan 24, 2009 at 4:25 AM
