2003 Ford F250 brake lights
79,000 MILES • V8 • 2WD • MANUAL
GKLEIN
when i depress the brake pedal the brake lights do not work. the fuse is good and the bulbs are good and operate correctly when the hazards are turned on.
any idea as to the problem?
Aug 10, 2008 at 11:51 AM
BLACKOP555
  • 10,386 POSTS
you have a third brake light in the window, does that work or no?
more then likely the brake switch has failed or is out of adjustment and needs to be looked at.
Aug 10, 2008 at 1:51 PM
