2003 Ford F-250 Dash &guages adn radio
2003 FORD F-250
135,000 MILES • V8 • 2WD • AUTOMATIC
PATRICKWIRTZ
My 2003 Ford F-250 has been developing an intermittent problem. While driving the guages will go crazy, radio will die, windows won't work, and then they willl all bounce arond and might be fine for a while. I ahve attmepted to troubleshoot the system by pulling fuses and relays while it is running to duplicate the problem but it will not duplicate it. I am assuming at this point it must be a body module of some sort, any suggestions
Oct 29, 2010 at 3:03 PM
TECH1FORD
  • 102 POSTS
all of this is ciontrolled by the fuse panel. You will need to make sure all of the grounds are good, if you remove the trim panel by the drivers foot, there are a few grouds make sure they are clean and tight. To diagnoise the fuse panel is very difficult you will need it happen more often.
Nov 1, 2010 at 2:15 AM
