2002 Ford F250 Solenoid
2002 FORD F-250
B32J
Electrical problem
2002 Ford F250 V8 Two Wheel Drive Automatic
Truck just makes a clicking noise when attempting to start. Tried to jump start did not. How do I test if solenoid, starter or relay?
Dec 22, 2008 at 2:26 AM
BLACKOP555
  • 10,386 POSTS
how to test the starter? jump the solenoid with a screwdriver if the starter starts cranking the vehicle then its good, if not and it keeps clicking, battery could be dead, no good or you have a corroded connection somewhere.
if it does crank good then suspect the solenoid for being at fault.
Dec 24, 2008 at 3:54 AM
