2002 Ford F-250 misfire under load
OCRIM504
  • 2002 FORD F-250
  • V8
  • 4WD
  • 55,000 MILES
Truck has run well until recently. There are no warning lights showing but the engine is missing at idle and violently when put under load. Where would you suggest I start. I did try injector cleaner.
Thanks, John
Tuesday, October 21st, 2008 AT 4:27 AM
Hi ocrim504 and welcome to 2carpros
Rough idle: A large vacuum leak can lean the air/fuel mixture out to such an extent that an engine will not idle at all. An EGR valve that is stuck open at idle can have the same effect as a vacuum leak. So too can a loose positive crankcase ventilation (PCV) hose, a leaky PCV valve or the wrong PCV valve (one that flows too much air for the application). If somebody replaced the PCV valve recently, they may have installed the wrong PCV valve. The rough idle in all of these cases is caused by "lean misfire." The fuel mixture is too lean to ignite reliably so it often misfires and fails to ignite at all. Lean misfire will show up as elevated hydrocarbon (HC) readings in the exhaust, which may be enough to cause a vehicle to fail an emissions test.
Misfiring when accelerating. This may be due to a vacuum leak, but it can also be caused by dirty fuel injectors, a weak fuel pump (low fuel pressure) or a faulty fuel pressure regulator. It can also be caused my ignition misfire due to worn or fouled spark plugs, bad spark plug wires, or weak ignition coil.
Tuesday, October 21st, 2008 AT 5:35 AM
