Friday, April 9th, 2010 AT 10:09 AM
I have a 02 F250 7.3 supercab longbed. I have recently started experiencing a steering issue. The wheel will pull relatively hard off center, usually to the left but it has pulled right. It is VERY intermittent. It happens right after a right hand 90deg turn. The wheel doesn't want to go back to straight, then it will lurch (usually left) requiring some force to get back straight. It will continue to jerk until I pull over. After it sits for a minute as I try in vain to find what came loose, the problem is gone. The first trip to the garage got a realignment, but the issue happened again this morning. I can't reproduce the issue on demand.
