Hi Phil.
This is a very old post so it is more than likely they will not respond but we will see what we can do to help out with this.
I suspect you are saying this is a cluster issue and you need to get it re-soldered. This very well could be the issue as that is a typical failure.
However, to verify this we need to check the power going into the cluster and the ground to make sure this is not a battery issue or a ground issue.
Basically, if you have power and ground then the issue is on the circuit board of the cluster.
So, then we need to check the battery voltage if the voltage is low because that will cause the gauges to blink as well.
The wiring diagram is below so please let me know what questions you have. Thanks
Images (Click to enlarge)
Apr 17, 2022 at 1:15 AM
