2002 Ford F250 Fuel pump fuse
162,000 MILES • V8 • 2WD • AUTOMATIC
ADKINSBJ
My fuel pump fuse would randomly blow, then it got worse and worse blowing almost every week, I replaced the fuel filter and fuel pump, the other day when the fuse blew, I could not got a new one in without it blowing, Is there a tendency for the wires to short out on the frame somewhere? Is there something that I should be looking at other than tracing the wires and seeing if the insulation is worn away?
Aug 11, 2008 at 9:20 AM
  • 75,988 POSTS
The dark green and yellow wire could be shorted to ground this is the power feed for the fuel pump thru the inertia switch.
Aug 11, 2008 at 9:28 AM
ADKINSBJ
where is that located?
Aug 11, 2008 at 9:29 AM
  • 75,988 POSTS
Find the inertia switch behind right kick panel and test from there-for a short circuit-be advised this problem can be a bear to fix BTDT. No electrical experience bring it in.
Aug 11, 2008 at 9:33 AM
ADKINSBJ
thanks, I think i found the problem, can I just run a different wire from the fuse box, and if so what do I hook it up to, the fuel pressure regulator or to some where else
Aug 12, 2008 at 9:02 AM
  • 75,988 POSTS
I need to know where did you find the problem-you cannot connect it to the pressure regulator there's no wiring connection there-
Aug 12, 2008 at 10:21 AM
