2002 Ford F250 Exhaust
100,000 MILES • V8 • 4WD • AUTOMATIC
JAKE D
The truck has the 5.4L gasser engine and when I bought the truck it had true dual exhaust installed with Magnaflow mufflers and the catalytic convertor was removed (very loud and "rappy"). I would like to put a catalytic convertor back on but would like to keep the true duals to improve performance. Should I install the stock convertor back onto the truck and run dual exhaust convertor back or mount 2 convertors to keep it true dual exhaust? Thanks,
Mar 19, 2008 at 10:56 PM
BLACKOP555
  • 10,386 POSTS
you should keep the TRUE dual and just put in the convertors.
cat back dual exhaust is not high performance it is just for looks and noise.
true dual is what gives you the performance, not cat back.
Mar 20, 2008 at 1:27 AM
