2002 Ford F250 Engine part replacement
2002 FORD F-250
119,000 MILES • V8 • 2WD • AUTOMATIC
ELIOCEL
Do I need to open or remove the engine in order to replace the engine oil dipstick TUBE ASSEMBLY?
Feb 14, 2009 at 5:53 PM
MERLIN2021
  • 17,250 POSTS
No it's got a single bolt holding it on the outside, remove the bolt, and pull, there is a rubber "O" ring at the bottom, install by pushing new one all the way in and installing the hold down bolt.
Feb 15, 2009 at 12:42 AM
