2002 Ford F250 Battery light in dash cluster
2002 FORD F-250
146,000 MILES • V8 • 4WD • AUTOMATIC
RDELESKI
A few weeks back we were drivong and i noticed the battery light came on in the dash cluster. It stayed on shortly and turned off, the time after thet it came on and stayed on for approx 15 min. We made it to out destination and had no more issues with it. This weekend however, as we were driving the whole electrical system died while we were moving. The enging was still running but the gauges, radio, and power windows were dead. I recently replaced the batteries due to age, i went to NAPA and had both the batteries and alternator tested. Both were in good working order. I chose to replace the alternator being that it was acting intermitently. Lastnight, with the new alt installed, the damn light came back on, so im at a loss for what the issue is. HELP!
Thank you
RJ Deleski
Jul 7, 2010 at 6:14 AM
Check fuse 45 and 64 if okay you need to test the wiring for open and shorts
Jul 7, 2010 at 8:17 AM
