2001 Ford F250 Oil preassure is down and something is leaki
2001 FORD F-250
20,000 MILES • V8 • 2WD • AUTOMATIC
PUSTOVOY
Recently on my car I had a light showing oil pressure is down or something happened. I start checking for a problem, flashed and changed oil but light is still on. After oil and filter change when I first start my car oil pressure showed at normal and than light when up again. I don't know if I have a problem with sensor and if there are a way to check or if I have a bigger problem with my oil pressure, or oil leak.
Sep 19, 2008 at 4:30 PM
If its normal when you checked the oil pressure I'd change out the oil pressure switch/sensor.
Sep 19, 2008 at 4:34 PM
