2001 Ford F250 hard to turn sterring wheel
100,000 MILES • V8 • 2WD • AUTOMATIC
EDGAR5
Hard to turn steering wheel. My diesel ford truck has full fluid,and no leaks in the steering pump. Also the belt is fine. What could it be the problem?
Aug 28, 2009 at 4:29 PM
MJR346
  • 132 POSTS
Could be the pump, some of the suspension/steering parts or the gearbox going south... One of the things is ,did you make sure to use Mercon or Mercon V ATF in the power steering?
Ford DOES NOT use power steering fluid, it uses automatic transmission fluid as power steering fluid
Aug 29, 2009 at 11:09 AM
