2001 Ford F250 Blown fuse
110,000 MILES • V8 • 2WD • AUTOMATIC
DARYL HOLLINGSWORTH
When I shift to drive or from drive to park it blows the instrument and gas pedal fuse. How do I fix this?
Jun 22, 2010 at 10:03 AM
KHLOW2008
  • 41,812 POSTS
Hi Daryl , Thank you for the donation. I need to confirm the fuse that is blowing to understand the problem better. Is it Fuse # 15 ( Red circle in diagram)?
https://images.2carpros.com/forum/automotive_pictures/192750_CentralFuseBox01F250Fig03_2.jpg
Jun 25, 2010 at 5:43 AM
DARYL HOLLINGSWORTH
No, it's number 19
Jun 25, 2010 at 5:48 AM
KHLOW2008
  • 41,812 POSTS
Since the fuse only blows when the gear shift is moved, I believe there is a short to body between the Tan/White wire of Transmission control Switch (TCS) and the PCM, terminal # 29.
Unplug the PCM and TCS and test for continuity of Tan/White wire to body. If continuity is present, the wire is shorted and you have to locate the source.
Jun 25, 2010 at 7:31 AM
DARYL HOLLINGSWORTH
You'll have break it down a little more. Where are these things, pms and the tcs
Jun 25, 2010 at 8:20 AM
KHLOW2008
  • 41,812 POSTS
PCM = Power Control Module. It should be the Auxiliary Power Control Module, located behind right side of dadsh.
TCS = Transmission Control Switch.
The transmission control switch (TCS) is a momentary contact switch that is located on the end of the transmission control selector lever. Pushing the TCS will either disengage or engage the overdrive function of the transmission. If the OVERDRIVE is disengaged, the word OFF will illuminate on the transmission control selector lever.
I believe the wire for the TCS is shorting somewhere and it most probably is near the shift lever.
Jun 26, 2010 at 12:32 AM
