2000 Ford F250 rear rotor removal
100,000 MILES • V8 • 4WD • AUTOMATIC
JEFO07
Is there a pin in the rear rotor and how do you get the rear rotor off?
Mar 21, 2009 at 10:38 AM
DAVE H
  • 13,383 POSTS
Removal & Installation (Explorer, Explorer Sport, Explorer Sport-Trac, E150/250, F150/250 & Mountaineer)
NOTE:On all models except E250 and F250, when removing rear brake rotor, it is not necessary to disconnect hydraulic lines.
Raise and support vehicle. Remove wheel. Remove brake hose-to-caliper bolt. Remove and plug brake hose. Remove caliper. See DISC BRAKE CALIPERS & PADS. Remove rotor.
To install, reverse removal procedure. Install NEW copper washers when installing brake hose-to-caliper bolt. Tighten bolts and nuts. See TORQUE SPECIFICATIONS. Bleed brakes. See BLEEDING BRAKE SYSTEM.
Mar 21, 2009 at 10:43 AM
