2000 Ford F250 Pinion Seal
22,000 MILES • V8 • 4WD • MANUAL
TWS1616
How do you change the pinion seal on a 2000 Ford F-250? I've got the driveshaft out of the way and the pinion nut off, but I can't get the yoke or flange off? Thanks for the help
Jun 23, 2009 at 6:57 AM
BMRFIXIT
  • 19,053 POSTS
Hammering on companion flange could result in damage to ring and pinion gear.
Using Puller (205-D026), remove pinion flange. Carefully remove pinion oil seal so as not to damage housing seal surface.
Jun 23, 2009 at 3:09 PM
