2000 Ford F250 location
120,000 MILES • V8 • 2WD • AUTOMATIC
MICHAEL EDWARDS
What is the loction for the fuel pump relay. I removed the fuel tank and pump. I am only getting 6.5 volts to the plug for the pump. I would like to check the relay but can not find its location. Truck was running ok till I parked it for two months then it would not start unless I sprayed sstarting fluid in the intake.
Sep 29, 2008 at 3:16 PM
  • 75,988 POSTS
The fuel pump relay is located in center of dash-sorry no pic
Sep 30, 2008 at 5:14 AM
