2000 Ford F-250 I cant start my truck
KOTATO
  • 2000 FORD F-250
  • V8
  • 4WD
  • 150,000 MILES
It crank but do not want start and Im not working I get laid off so please give me some help
Saturday, May 2nd, 2009 AT 3:47 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, May 2nd, 2009 AT 5:26 AM
BMRFIXIT
  • 19,053 POSTS
1st step would be checking fuses
2nd turn key on and listen to the fuel pump is it coming on
check fuel pressure
check for spark
not sure how to do so check the links on the left side of this page
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, May 2nd, 2009 AT 5:29 AM
