2000 Ford F250 Electrical Malfunctions
150,000 MILES • V8 • 2WD • MANUAL
JIM6395
The other day when I got in my truck to leave work, the heater motor was running with the ignition off. The next morning when I left for work, the air bag warning light came on and the heater motor still will not shut off with the ignition key. And now, the third day my cruise control stopped working and my speedometer is jumping around.
Last winter my heater motor was doing the same thing as described above but this time when i tried to set the cruise the horn would honk. About 2 hours later when the truck was parked the horn started to blare and the only way I could get it to stop was to disconnect the batteries. After a couple of days I re-hooked the batteries and everything was fine until now.
Oct 13, 2009 at 11:18 PM
2CARPRO JACK
  • 11,533 POSTS
Look for any signs of water damage at the power block , lower left side of dash,if none is present you may have a GEM (generic electronic module) that is failing, almost all electric items go through this module, fairly common
Oct 19, 2009 at 5:45 AM
