what is the minimum width a rear rotor on 2000 ford F250 can be turned?
Jan 12, 2010 at 3:00 PM
BLUELIGHTNIN6
✓Experienced Mechanic
1.102" is the discard thickness
Jan 12, 2010 at 3:07 PM
ZUE
MEMBER
In the future you will find the minimum thickness for the rotor (as well as drums) stamped on the actual rotor. Clean it off with a rag and you should find the min. thickness for any rotor.
