2000 Ford F250
209,256 MILES • V8 • 4WD • AUTOMATIC
PHATBOYZBNY
hi i have a 2000 ford f250 and the dome light dont work at all from the door a switch the bulbs are good.
and my speedo dont work but the miles do work but the mph dont work what can it be
thanks al.
Feb 4, 2008 at 11:36 AM
SELPHDANNY
cant help you with the dome light but i can with you speedo problem. just wondering if your abs light is on and if it is there is a sensor in the rear end of your truck called the abs sensor and it has gone bad. ford sells it for 25 bucks and it is easy to change out. one bolt and a wire clip and your done.
Apr 16, 2008 at 11:38 PM
