Brakes problem
2000 Ford F-250 V8 Two Wheel Drive Automatic 140K miles
I have a minor brake fluid leak at the interior side of the firewall were the brake actuator rod enters the master cylinder assembly.
Is that most likely the hydraulic booster seal?
Should I replace the master cylinder as well as the booster?
Oct 31, 2010 at 4:17 AM
