1999 Ford F250 Rear differential failure
13,900 MILES • V12 • 4WD • AUTOMATIC
GLOBIL
About a month ago I had a flat tire on the rear axle of my 1999 Ford F-250 XLT. I used the full size spare which was the same size as other tires currently on the truck. 2 days later the differential started making noise and had to be replaced. I asked at the dealership if they could tell me why it failed. They told me that it was because I used my spare tire on one side of the rear axle. Because the spare had no wear and the other tire was worn, and because the tires were made by different manufacturers in different years that the tires circumferance was different, and that driving for 2 days like this caused the problem. I've had friends tell me this is not true, since race cars use stagger and this is done by running different size tires , and that the purpose of the differential is to compensate for this. I am now going to buy new tires and need to know who's right so I know whether to buy 4 or 5 tires.
Jul 5, 2008 at 2:14 AM
KHLOW2008
  • 41,812 POSTS
Hi globil,
Differences in tire size can cause the differential to break down if equipped with LSD and driven at high speed whereby the LSD tends to lock up due to the difference in wheel speed.
Apart from that there should be no other reasons. If transfer gear has no differential lock, then it is ok to replace front or rear two at a time.
Jul 6, 2008 at 5:24 AM
