1999 Ford F250 Power Windows
1999 FORD F-250
169,000 MILES • V8 • 4WD • AUTOMATIC
GGILLGPS
The power window on the driver side is stuck 1/2 way down. I recently replaced the switch and I can hear the relay in the fuse box click when I try to put the window up or down. I am reasonably sure it is the regulator but would like a more educated opinion before spending $200+ on the part. Also I am not sure how to gain access beyond removing the outer door panel.
Oct 21, 2009 at 5:33 AM
MERLIN2021
  • 17,250 POSTS
http://www.2carpros.com/how_to/power_window.htm
This will help, Need to test for power at the motor.
Oct 21, 2009 at 6:09 AM
