1999 Ford F250 interior dome light
150 MILES • V8 • 4WD • AUTOMATIC
MXALEX229
  • 8 POSTS
I recently bought a dmoe light and I can not install it, I'm not sure what I am missing but I belive it might be some sort of relay wire. What is it? and where might I find one?
Dec 17, 2009 at 5:50 AM
RACEFAN966
  • 5,029 POSTS
How do you mean can't install it? Is there no place for it or ?
Dec 18, 2009 at 1:59 AM
MXALEX229
  • 8 POSTS
No there is a place to install it, but I belive I am missing a wire here, I'm not sure, becuase it looks like everything is there but it still doesn't work.
https://images.2carpros.com/forum/automotive_pictures/450225_GetAttachment_1.jpg
https://images.2carpros.com/forum/automotive_pictures/450225_GetAttachment2_2.jpg
Dec 18, 2009 at 11:39 PM
RACEFAN966
  • 5,029 POSTS
So are telling me that it won't come on? It is two wire both power. The light when it is screwed in grounds through the body with one of the mounting screws. I need to know if this is a F250 super duty or not to get the right wiring diagram. Get back to me with that.
Dec 19, 2009 at 1:22 AM
MXALEX229
  • 8 POSTS
[quote:90eb650152="racefan966"]So are telling me that it won't come on? It is two wire both power. The light when it is screwed in grounds through the body with one of the mounting screws. I need to know if this is a F250 super duty or not to get the right wiring diagram. Get back to me with that.[/quote:90eb650152]
yes, it is an f250 super duty xl, i screwed the light in and grounded it but it still wont turn the light on, I replaced the bulbs fuses etc... so I figure it must be something with the wiring, I just dont know what exactly.
Dec 19, 2009 at 6:01 AM
RACEFAN966
  • 5,029 POSTS
I am thinking it is either a door pin switch or the Gem module or interior lamp relay. Do you have a test light or digital multi meter so we can do some tests to figure out witch? So tell me is there any other lights that don't work inside? Here is what I see with the wiring diagram. It starts with fuse 14 (10 amp) in the junction box behind the lower leftfront of the dash. Then to the interior lamp relay then it goes out the interior lighting (all). So the other thing I need to know is regular or extra cab or 4 door? So check for power at the blue wire with the black stripe for power when the door is open or when you turn the switch on. If now power then I need you to check for power at the orange wire with the light green stripe that goes to the main dome light switch. Let me know what you find.
Dec 21, 2009 at 4:50 AM
MXALEX229
  • 8 POSTS
I checked the fuse box, It seems after tracing it there is no interior lamp relay to begin with. It must have been sold as parts before I bought it. It is only a regualr cab though. Would you guys know any place I could get the relay for the interior lighting?
Dec 21, 2009 at 10:15 AM
RACEFAN966
  • 5,029 POSTS
Ok of course you can go to Ford or you can go to your local parts store. Napa part number is AR606 and looks to cost about 8 dollars. Let me know if this takes care of it.
Dec 22, 2009 at 1:53 AM
MXALEX229
  • 8 POSTS
thanks i'll get back to you soon as it is installed, your time and service has been very much appreciated.
Dec 22, 2009 at 7:24 AM
RACEFAN966
  • 5,029 POSTS
Thanks and do let me know how it goes. If this don't fix it then we will look into other things. Did you buy this truck used and the dome light didn't work? I am thinking that the light wouldn't go off, so they removed the relay, if that is the case then you will need to replace the door pin switches that turn the light on and off. Let me know how it goes.
Dec 23, 2009 at 1:50 AM
MXALEX229
  • 8 POSTS
hey I bought the relay, it didn't fix the problem, but we took another step forward seeing as how there was no relay there before. All the relays are missing actually, there was only one in and it was the third down. Could that have anything to do with it?. And when I bought the truck there was no light at all, just a few wires comming out of the truck where the light should hav been.
Dec 23, 2009 at 7:13 AM
RACEFAN966
  • 5,029 POSTS
Ok so just to go over things lets see if there is power first. Now fuse number 4 and number 14 check them both should be 10 amp. My next question is do any of the courtesy lights work? I know the dome light don't work but does the glove box light work and the under hood light etc? Also what color wires are at the dome light?
Dec 28, 2009 at 11:14 AM
MXALEX229
  • 8 POSTS
no, none of the courtesy lights work, and the wires from the dome are green and black. I have not checked for power yet I just got the tool the other day and I am waiting for it to arrive.
Dec 30, 2009 at 7:13 AM
RACEFAN966
  • 5,029 POSTS
I could also be that the GEM Module is not doing its job but we will check that when we get to that point. At this point just make sure you have power in and out ot fuse 4 and 14. Get back to me with that so we can figure out where to go from that point.
Dec 31, 2009 at 2:25 AM
