1999 Ford F250 fuel pressure
190,000 MILES • V8 • 4WD • AUTOMATIC
BEAR65
  • 5 POSTS
99 f250 4x4 super duty Fuel pressure cold only at about 32 psi dropping to about 28 psi running. Have cleaned injectors,replaced fp regulator,replaced fuel filter....could sensors be bad without a code.. any ideas....what should my pressure optimally be ....help
Feb 6, 2010 at 3:12 AM
  • 75,988 POSTS
Hi bear65, Welcome to 2carpros and TY for the donation what should my pressure optimally be-See below
https://images.2carpros.com/forum/automotive_pictures/12900_f250_1.jpg
Feb 6, 2010 at 6:04 AM
BEAR65
  • 5 POSTS
any ideas what might be causing the low pressure other than what I have tried
Feb 6, 2010 at 7:05 AM
  • 75,988 POSTS
Could be low voltage to the pump, intank pick-up sock or the fuel pump itself is weak
Feb 6, 2010 at 7:18 AM
BEAR65
  • 5 POSTS
is there a specific test to check if fuel pump is weak
and how much voltage should there be at the pump
Feb 6, 2010 at 8:57 AM
  • 75,988 POSTS
If it doesn't meet the specs above by using a fuel pressure gauge. Also check if you have a low pressure pump in the tank and also an external one-The voltage should be 10volts and higher
Feb 6, 2010 at 11:28 AM
