1999 Ford F250 Bank 1 bank 2 to lean
1999 FORD F-250
102,000 MILES • V8 • 4WD • AUTOMATIC
DAN SCHWAB
bank1 and bank2 to lean is my problem and it idles high when I first start the truck and it idles up and down after it idles down I changed the throdle postioning sensor and I was told to clean my maf sensor nothing helped if any one has a sugestion i would appreciate it thanks
Aug 25, 2010 at 9:45 AM
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Aug 25, 2010 at 10:54 AM
