1998 Ford F250 Torque specs
JJAXN
Brakes problem
1998 Ford F250 6 cyl Two Wheel Drive Automatic
I'm doing the front brakes and i'm trying to find out what the torque specs are for the spindle nut if there are any.
Jun 9, 2010 at 2:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
tighten to 30 ft. lbs, then loosen 2 full turns. then tighten again to 17 - 24 ft. lbs. back off nut 175 degrees. tighten one last time to 17 INCH lbs
Jun 9, 2010 at 8:22 AM
