1997 Ford F-250 stalling
FORD974X4
  • 1997 FORD F-250
Engine Mechanical problem
1997 Ford F250 V8 Four Wheel Drive Automatic
truck stalls when I stop at a stop sing or get a red light what can I do to fix the problem.
Tuesday, December 22nd, 2009 AT 4:11 AM
Clean out Idle air control valve and test the throttle position sensor and mass air flow sensor to include the EGR valve.
Wednesday, December 23rd, 2009 AT 3:23 AM
MRFIXIT77845
  • 6 POSTS
If your truck is a diesel then check your tranny fluid if its low it wont release the automatic clutch and it stalls the truck when put in gear or stoping also make sure oil level is good as that controls your injection pump
Wednesday, January 13th, 2010 AT 7:47 PM
