1997 FORD F250 running rich at idle
LARRY383
  • 7 POSTS
i have a f250 with a 351 and i plug it into a scanner and it sed under 02 senser that it was rich i had the motor at idle, what is the main reson that would make it say it is rich ? what part is most likley the part that needs to be changed? thanks for any info
Oct 29, 2007 at 11:00 AM
BLACKOP555
  • 10,386 POSTS
Check the o2 sensor first. if nothing check the MAF and Coolant temp sending unit.
Oct 29, 2007 at 12:16 PM
BURTBOSTWICK
[quote:e91e1dc82f="larry383"]i have a f250 with a 351 and i plug it into a scanner and it sed under 02 senser that it was rich i had the motor at idle, what is the main reson that would make it say it is rich ? what part is most likley the part that needs to be changed? thanks for any info[/quote:e91e1dc82f]mine was sucking gas right threw the fuel pressure regulater
Dec 16, 2007 at 12:48 AM
