1997 Ford F250 head lights blink on and off
145,000 MILES • V8 • 4WD • AUTOMATIC
VENTRON
My head lights have started blinking on and off after being on for 10 minutes. I beleive the problem is in the head light switch? How difficult is it to change this switch? Is it a front of dash or a behind the dash reapair
Thanks
Grant
Dec 31, 2008 at 6:16 AM
JAMES W.
  • 2,394 POSTS
The switch itself is behind the dash. Bad switches have been a real problem with Fords.The switch contacts heat up and start to arc. When you get the old switch out, you may see some burned terminals in the socket.
Dec 31, 2008 at 10:59 AM
