1997 Ford F250 Evap large leak code
1997 FORD F-250
189,000 MILES • V8 • 2WD • AUTOMATIC
WAYNECOPREACHER
The Pcm is detecting an Evap large leak. I have traced lines and found no faults. I was thinking maybe the IAC was at fault or the PCV valve. Not sure tho. Dont have any tools to test the system.
Apr 27, 2010 at 3:02 PM
BLACKOP555
  • 10,386 POSTS
wouldnt be those. theres a valve on the tank. and then theres a vapor line running up to the charcoal canister. from there to the purge solenoid and then to the manifold.
best thing to do is get a smoke tester to do it because altho it says large leak. it can be very tiny.
also did you check the gas cap?
Apr 28, 2010 at 5:25 AM
