1997 Ford F250 dual gasoline tanks
1997 FORD F-250
19,000 MILES • V8 • 2WD • AUTOMATIC
DARLENE BOOR
On the switchover from front tank to rear tank, the
gas gauge gives volume left for rear tank, but does
not read any volume for front tank.
What is the problem, and how could this be remedied.
Thanks.
Apr 15, 2010 at 12:41 PM
DAVE H
  • 13,384 POSTS
Fuel Delivery Assembly (FDA)
The FDA consists of a fuel pump inside a reservoir that is attached to the pump and sender assembly. See Fig. 1. In a 2-tank system, there is one FDA per tank. Fuel sender assembly handles the fuel switching through internal valves.
Fuel reservoir is used to prevent fuel flow interruptions during extreme vehicle maneuvers when fuel tank level is low. Reservoir is located in-tank and is either molded or welded into fuel tank or is part of FDA.
Shuttle valve opens fuel return line to fuel tank when fuel pressure on shuttle diaphragm exceeds opposing check valve spring force. When pump is de-energized, supply check valve closes to maintain pump prime and fuel supply line pressure.
A portion of high pressure flow from the pump is diverted to operate the venturi jet pump. The jet pump draws fuel from the tank into the FDA. This ensures adequate fuel supply during extreme vehicle maneuvers and steep vehicle attitudes when fuel level is low. If FDA is defective, it must be replaced as an assembly.
Apr 15, 2010 at 2:27 PM
