1997 Ford F250 Diesel fuel leak
FFRASER99
Engine Mechanical problem
1997 Ford F250 V8 Two Wheel Drive Automatic
I have slow dripping leak at the location noted on the attached picture.[img:8cfd72c659]http://www.2carpros.com/forum/automotive_pictures/556404_F250_leak_1.jpg[/img:8cfd72c659]
Jul 30, 2010 at 1:51 PM
  • 31,937 POSTS
Hi there,
thank you for the donation,
If the leak is from the rolled edge around the black section of the sensor it will have to be replaced, if from the thread, this should be a tapered gas thread so try and nit it up a bit, if it continues to leak (from the thread, remove and check housing for any signs of cracking at the thread.
mark (mhpautos)
Jul 30, 2010 at 7:00 PM
