1997 Ford F250
1997 FORD F-250
41,000 MILES • V8 • 2WD • MANUAL
CHRIS BEAUVAIS
I have a 1997 ford f-250 with the 460 cid gas engine. It sat up for about 6 months and now won't start. It turns over well. I do not see any spark between one of the tits on the distributor cap and any plug wire. Please help.
Mar 8, 2008 at 7:45 AM
BLACKOP555
  • 10,386 POSTS
take and use a spark tester at each cylinder and post back what you find.
Mar 9, 2008 at 1:55 AM
CHRIS BEAUVAIS
[quote:eec7803719="blackop555"]take and use a spark tester at each cylinder and post back what you find.[/quote:eec7803719]
No spark at any wire while cranking.
Mar 9, 2008 at 12:35 PM
BLACKOP555
  • 10,386 POSTS
hook a spark tester up to the wire coming direct from the coil, let me know if you are gettign spark there.
Mar 9, 2008 at 2:06 PM
CHRIS BEAUVAIS
yes I did that too and no spark indication
Mar 9, 2008 at 9:51 PM
BLACKOP555
  • 10,386 POSTS
since that is the case you should check to see that the crank shaft sensor CKPS is functioning properly, if that is good then the problem is in the ignition module or in the coil itself.
if you would like i could explain how to do a test on a coil or you can take it in and have it checked for free at autovalue or autozone.
Mar 10, 2008 at 1:42 AM
